Saltar al contenido principal
Fujitsu Lifebook S6120 Fan Replacement
Qué necesitas
  1. Fujitsu Lifebook S6120 Fan Replacement, Battery: paso 1, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement, Battery: paso 1, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement, Battery: paso 1, imagen 3 de 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: paso 2, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: paso 2, imagen 2 de 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Fan Replacement: paso 3, imagen 1 de 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Fan Replacement: paso 4, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 4, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 4, imagen 3 de 3
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Fan Replacement: paso 5, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 5, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 5, imagen 3 de 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Fan Replacement, Keyboard: paso 6, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: paso 6, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: paso 6, imagen 3 de 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Fan Replacement: paso 7, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 7, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: paso 8, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: paso 8, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: paso 8, imagen 3 de 3
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Fujitsu Lifebook S6120 Fan Replacement: paso 9, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 9, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 9, imagen 3 de 3
    • Use tweezers to remove the wires from the Adapter.
  10. Fujitsu Lifebook S6120 Fan Replacement: paso 10, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement: paso 10, imagen 2 de 2
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Fujitsu Lifebook S6120 Fan Replacement, Motherboard: paso 11, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement, Motherboard: paso 11, imagen 2 de 2
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  12. Fujitsu Lifebook S6120 Fan Replacement: paso 12, imagen 1 de 1
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  13. Fujitsu Lifebook S6120 Fan Replacement: paso 13, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement: paso 13, imagen 2 de 2
    • Remove the ribbon from the motherboard with a pair of tweezers.
  14. Fujitsu Lifebook S6120 Fan Replacement: paso 14, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 14, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 14, imagen 3 de 3
    • Use a 5mm nut driver to unscrew the nuts.
  15. Fujitsu Lifebook S6120 Fan Replacement: paso 15, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement: paso 15, imagen 2 de 2
    • Pull the ribbon tab up and off the motherboard.
  16. Fujitsu Lifebook S6120 Fan Replacement: paso 16, imagen 1 de 1
    • Remove the metal plate covering the motherboard.
  17. Fujitsu Lifebook S6120 Fan Replacement: paso 17, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement: paso 17, imagen 2 de 2
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  18. Fujitsu Lifebook S6120 Fan Replacement: paso 18, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement: paso 18, imagen 2 de 2
    • Pinch your fingers around the base of the connector and pull it out.
  19. Fujitsu Lifebook S6120 Fan Replacement: paso 19, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement: paso 19, imagen 2 de 2
    • Lift the motherboard off the plastic base.
  20. Fujitsu Lifebook S6120 Fan Replacement, Fan: paso 20, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement, Fan: paso 20, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement, Fan: paso 20, imagen 3 de 3
    • Using a Philips head size #0 remove the 3mm screw on the back of the motherboard.
  21. Fujitsu Lifebook S6120 Fan Replacement: paso 21, imagen 1 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 21, imagen 2 de 3 Fujitsu Lifebook S6120 Fan Replacement: paso 21, imagen 3 de 3
    • Using tweezers detach the cable from the motherboard.
  22. Fujitsu Lifebook S6120 Fan Replacement: paso 22, imagen 1 de 2 Fujitsu Lifebook S6120 Fan Replacement: paso 22, imagen 2 de 2
    • The fan can now be removed from the motherboard.
Conclusión
Jessi Gallant
Miembro Desde 03/19/18
899 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 632
