Introducción
If your laptop is slowing down without warning, or you just want to upgrade the system's memory, then you will need to remove your RAM. This guide will show you the steps for this process.
Herramientas
Partes
No se especificaron partes.
Flip your laptop such that the bottom of the laptop is facing up.
Make sure you can read the label on the bottom part. If the label is upside down, you will need to re-position the laptop until you can properly read it. As an alternative, the hinges for the screen should be facing towards you.
The RAM compartment will be located towards the bottom-left corner. It will be behind the cover held in place by a 6 mm screw
Using a Phillips #1 screwdriver, remove the 6 mm screw by turning your screwdriver counter-clockwise.
