Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fujitsu LifeBook U810 Wireless LAN card Replacement
Qué necesitas
  1. Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: paso 1, imagen 1 de 3 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: paso 1, imagen 2 de 3 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: paso 1, imagen 3 de 3
    • Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  2. Fujitsu LifeBook U810 Wireless LAN card Replacement: paso 2, imagen 1 de 3 Fujitsu LifeBook U810 Wireless LAN card Replacement: paso 2, imagen 2 de 3 Fujitsu LifeBook U810 Wireless LAN card Replacement: paso 2, imagen 3 de 3
    • Remove the two 5mm screws with a Phillips #0 screwdriver.
    • Remove the wireless LAN card from the device.
    Pregunta a FixBot
    Agregar Comentario
  3. Fujitsu LifeBook U810 Wireless LAN card Replacement: paso 3, imagen 1 de 2 Fujitsu LifeBook U810 Wireless LAN card Replacement: paso 3, imagen 2 de 2
    • Detach the two antenna cables connected to the wireless LAN card by gently pulling them out of place.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Anne Kutt
Miembro Desde 10/22/18
197 Reputación
1 Guía escrita
Equipo
UC Davis, Team S4-G7, Lore Fall 2018 Miembro de UC Davis, Team S4-G7, Lore Fall 2018
UCD-LORE-F18S4G7
Miembros de 3
4 Guías creadas
2Guía Comentarios
Is there a BIOS whitelist for this machine? I wanted to replace my wifi card due to OS incompatibility but I've seen conflicting reports.
Adam Birnbaum - Contestar Compartir
No whitelist. Any card that physically fits seems to work.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 39
Todo El Tiempo: 1,184
