Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fujitsu LifeBook N3510 Wireless Module Replacement
Qué necesitas
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Battery: paso 1, imagen 1 de 1
      • Locate the two clips on the bottom of the computer that support the battery.
      Pregunta a FixBot
      Agregar Comentario
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 2, imagen 1 de 1
      • Using your fingers, push the clips inward and then upward.
      • Lift the battery out of the computer.
      Pregunta a FixBot
      Agregar Comentario
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: paso 3, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: paso 3, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: paso 3, imagen 3 de 3
      • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
      Pregunta a FixBot
      Agregar Comentario
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 4, imagen 1 de 1
      • Lay the computer flat on a stable surface with the monitor pointing away from you.
      Pregunta a FixBot
      Agregar Comentario
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 5, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 5, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 5, imagen 3 de 3
      • Use a spudger to partially lift the hinge cover.
      Pregunta a FixBot
      Agregar Comentario
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 6, imagen 1 de 2 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 6, imagen 2 de 2
      • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
      • Lift the hinge cover enough to expose the ribbon cable.
      Pregunta a FixBot
      Agregar Comentario
    5. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 7, imagen 1 de 2 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 7, imagen 2 de 2
      • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
      Pregunta a FixBot
      Agregar Comentario
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: paso 8, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: paso 8, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: paso 8, imagen 3 de 3
      • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
      • Lift the keyboard enough to expose the ribbon cable.
      Pregunta a FixBot
      Agregar Comentario
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 9, imagen 1 de 2 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 9, imagen 2 de 2
      • Use a spudger to release the ribbon cable from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 10, imagen 1 de 2 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 10, imagen 2 de 2
      • After the ribbon has been detached, carefully remove the keyboard.
      Pregunta a FixBot
      Agregar Comentario
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Metal Motherboard Cover: paso 11, imagen 1 de 1
      • Remove the following screws, all labeled "3."
      • Two 8.63mm screws.
      • One 7.65mm screw.
      • One 5.74mm screw.
      • Remove the following screw, labeled "15."
      • One 17.81mm screw.
      Pregunta a FixBot
      Agregar Comentario
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 12, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 12, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 12, imagen 3 de 3
      • Lift the cover with fingers and remove.
      Pregunta a FixBot
      Agregar Comentario
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Display: paso 13, imagen 1 de 1
      • Remove labeled screws.
      Pregunta a FixBot
      Agregar Comentario
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 14, imagen 1 de 1
      • Remove the screws from the bottom of the hinge as shown in the image.
      Pregunta a FixBot
      Agregar Comentario
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 15, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 15, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 15, imagen 3 de 3
      • Use a spudger to detach and remove cables from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 16, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 16, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 16, imagen 3 de 3
      • Unplug highlighted cables from the wireless module.
      Pregunta a FixBot
      Agregar Comentario
    5. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 17, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 17, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement: paso 17, imagen 3 de 3
      • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
      Pregunta a FixBot
      Agregar Comentario
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Top Palm Rest Cover: paso 18, imagen 1 de 1
      • Remove the 4 labeled screws.
      Pregunta a FixBot
      Agregar Comentario
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 19, imagen 1 de 1
      • Remove screws from bottom of laptop as shown in the picture.
      Pregunta a FixBot
      Agregar Comentario
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 20, imagen 1 de 1
      • Lift the palm rest cover from the base of the laptop.
      • You may use spudger if needed, lift from the front corners as shown.
      Pregunta a FixBot
      Agregar Comentario
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 21, imagen 1 de 1
      • Great job! You have successfully removed the old palm rest cover.
      Pregunta a FixBot
      Agregar Comentario
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: paso 22, imagen 1 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: paso 22, imagen 2 de 3 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: paso 22, imagen 3 de 3
      • Push securing clips outward, the wireless module will pop out.
      • Remove the wireless module.
      Pregunta a FixBot
      Agregar Comentario
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: paso 23, imagen 1 de 1
      • A picture of the removed wireless module is shown to the left.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Neil Daniels
Miembro Desde 01/17/11
1,411 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 5-18, Amido Winter 2011 Miembro de Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
Miembros de 3
23 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 2,902
