Saltar al contenido principal
Fujitsu LIFEBOOK P7010D Hard Drive Replacement
Qué necesitas
  1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop upside down on a table.
  2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 2, imagen 1 de 1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 3, imagen 1 de 1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: paso 4, imagen 1 de 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: paso 4, imagen 2 de 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: paso 4, imagen 3 de 3
    • Push the tab down as far as possible using your finger or plastic opening tool to unlock the disc drive.
    • While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
  5. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 2
    • On the bottom of the laptop, find the bottom-plate screw holes. They are located near the disc drive. Parallel to them is a 2.4mm screw.
    • After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew.
  6. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 6, imagen 1 de 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Flip the laptop over and open it facing you.
    • Use a spudger to lift the bottom black cover on both sides.
    • The cover is connected to an aluminum strip, so be careful lifting it.
    • For the proceeding steps, put on an anti-static wrist strap and clip it to something metal. Ensure that it's clipped to a grounded metal in order to protect the delicate circuitry inside the computer.
  7. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 7, imagen 1 de 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 7, imagen 2 de 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 7, imagen 3 de 3
    • Once the black cover is lifted, flip it and set it on the keyboard.
    • Locate the hardware disc on the right side and gently lift it out. Place it on the side of the laptop.
    • The hard drive is connected with a strip, so be careful when lifting it out.
  8. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 8, imagen 1 de 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 8, imagen 2 de 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: paso 8, imagen 3 de 3
    • Flip the hard drive on its side.
    • The pins connected to the hard drive are extremely fragile. Take care in handling the next few steps.
    • Hold the hard drive and use a spudger, preferably a wider one, to remove the black pin holder on the side where it touches the hard drive.
    • Gently wiggle the black pin holder back and forth, on each side, until the holder comes off.
Conclusión
3 personas más completaron esta guía.
Nicholas Ross
Miembro Desde 01/20/12
186 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-31, Amido Winter 2012 Miembro de Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
5 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 5,324
