Saltar al contenido principal
Fujitsu Esprimo Mobile V6555 HDD Replacement
Qué necesitas
  1. Fujitsu Esprimo Mobile V6555 HDD Replacement, Removing battery: paso 1, imagen 1 de 2 Fujitsu Esprimo Mobile V6555 HDD Replacement, Removing battery: paso 1, imagen 2 de 2
    • Turn your notebook over.
    • For safety reasons, remove battery. Pull switch on the right inwards. Do the same with the one on left side. Hold it, then pull out the battery.
  2. Fujitsu Esprimo Mobile V6555 HDD Replacement, Opening HDD cover: paso 2, imagen 1 de 2 Fujitsu Esprimo Mobile V6555 HDD Replacement, Opening HDD cover: paso 2, imagen 2 de 2
    • Now remove screw holding HDD cover.
    • Remove cover by pulling upwards form left.
  3. Fujitsu Esprimo Mobile V6555 HDD Replacement, Pulling HDD out: paso 3, imagen 1 de 2 Fujitsu Esprimo Mobile V6555 HDD Replacement, Pulling HDD out: paso 3, imagen 2 de 2
    • Pull HDD holder to the left by its ribbon. Now you can lift up your HDD.
    • To remove HDD from its holder, remove 4 screws on both sides of HDD holder.
Conclusión
Michał Kurda
Miembro Desde 02/17/22
866 Reputación
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 72
