Introducción
Replacing the hard drive for the Fujitsu Lifebook U810 can be a simple process if directions are followed carefully. The only tool required is a Phillips head +J0 sized screwdriver to remove the Phillips screws on the back of the LifeBook. This guide improves the memory and speed of the device. You can find a new hard drive online by searching the model number and corresponding part for the U810 model.
Partes
No se requieren partes.
  1. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
    • Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the two 5mm screws with a Phillips #0 screwdriver. Remove the hard drive from the LifeBook. Remove the hard drive from the LifeBook.
    • Remove the two 5mm screws with a Phillips #0 screwdriver.
    • Remove the hard drive from the LifeBook.
  4. Detach the two wires connected to the hard drive by gently pulling them out of place. Detach the two wires connected to the hard drive by gently pulling them out of place.
    • Detach the two wires connected to the hard drive by gently pulling them out of place.
Conclusión
Anne Kutt
Miembro Desde 22/10/18
197 Reputación
1 Guía escrita
Equipo
UC Davis, Team S4-G7, Lore Fall 2018 Miembro de UC Davis, Team S4-G7, Lore Fall 2018
UCD-LORE-F18S4G7
3 Miembros
2 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 6
Todo El Tiempo: 62
