Saltar al contenido principal
Fujifilm X-M1 Disassembly
Qué necesitas
  1. Fujifilm X-M1 Disassembly, Fujifilm X-M1 Disassembly: paso 1, imagen 1 de 1
    • If you haven't done so already, remove the lens from the camera.
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  2. Fujifilm X-M1 Disassembly: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  3. Fujifilm X-M1 Disassembly: paso 3, imagen 1 de 1
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  4. Fujifilm X-M1 Disassembly: paso 4, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 4, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 4, imagen 3 de 3
    • Remove the six 6.5 mm Phillips screws from the lens mount.
    • Use tweezers to remove the top metal ring and the thin metal ring below it .
  5. Fujifilm X-M1 Disassembly: paso 5, imagen 1 de 1
    • Remove the four 4.3 mm screws securing the sensor to the front case.
  6. Fujifilm X-M1 Disassembly: paso 6, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 6, imagen 2 de 2
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  7. Fujifilm X-M1 Disassembly: paso 7, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 7, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 7, imagen 3 de 3
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  8. Fujifilm X-M1 Disassembly: paso 8, imagen 1 de 1
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  9. Fujifilm X-M1 Disassembly: paso 9, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 9, imagen 2 de 2
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  10. Fujifilm X-M1 Disassembly: paso 10, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 10, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 10, imagen 3 de 3
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  11. Fujifilm X-M1 Disassembly: paso 11, imagen 1 de 1
    • Slide the frame around the LCD to remove it from the camera.
  12. Fujifilm X-M1 Disassembly: paso 12, imagen 1 de 1
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  13. Fujifilm X-M1 Disassembly: paso 13, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 13, imagen 2 de 2
    • Use tweezers to unhook the speaker near the left handgrip.
  14. Fujifilm X-M1 Disassembly: paso 14, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 14, imagen 2 de 2
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  15. Fujifilm X-M1 Disassembly: paso 15, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 15, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 15, imagen 3 de 3
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
  16. Fujifilm X-M1 Disassembly: paso 16, imagen 1 de 1
    • Use tweezers to remove the three pieces of tape covering the components of the motherboard.
  17. Fujifilm X-M1 Disassembly: paso 17, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 17, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 17, imagen 3 de 3
    • Desolder the three pairs of red and black wires attached to the mother board.
    • Learn more about desoldering wires here.
  18. Fujifilm X-M1 Disassembly: paso 18, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 18, imagen 2 de 2
    • Use tweezers to remove the grey cushion located below the flash button.
  19. Fujifilm X-M1 Disassembly: paso 19, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 19, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 19, imagen 3 de 3
    • Use two fingers to remove the two ribbon cables in the bottom left corner of the motherboard.
  20. Fujifilm X-M1 Disassembly: paso 20, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 20, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 20, imagen 3 de 3
    • Use the flat end of a spudger to unlock the four indicated ZIF connectors.
    • Use two fingers to pull the ribbon cables out of the connectors.
  21. Fujifilm X-M1 Disassembly: paso 21, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 21, imagen 2 de 2
    • Remove the 3.3 mm Phillips screw from the upper left corner of the motherboard.
    • Remove the 2.4 mm Phillips screw in the bottom right corner of the motherboard.
    • Use two fingers to remove the motherboard from the front case.
  22. Fujifilm X-M1 Disassembly: paso 22, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 22, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 22, imagen 3 de 3
    • Use tweezers to remove the black plastic tape at the top of the battery compartment.
    • Insert a Phillips #00 screwdriver through the hole beneath the black tape to remove a 4.8 mm screw.
    • Insert a Phillips #00 screwdriver through the white tamper evident sticker to remove a second 4.8 mm screw.
  23. Fujifilm X-M1 Disassembly: paso 23, imagen 1 de 1
    • Remove the 3.7 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 4.2 mm Phillips screw from the bottom of the sensor mount.
    • Remove the 6.2 mm Phillips screw hiding between the sensor mount and the battery compartment.
  24. Fujifilm X-M1 Disassembly: paso 24, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 24, imagen 2 de 2
    • Press the flash button to release the flash assembly.
    • Remove the 3.4 mm Phillips screw in the back of the flash compartment.
  25. Fujifilm X-M1 Disassembly: paso 25, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 25, imagen 2 de 2
    • Remove the top plate.
  26. Fujifilm X-M1 Disassembly: paso 26, imagen 1 de 1
    • Remove the sensor assembly.
  27. Fujifilm X-M1 Disassembly: paso 27, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 27, imagen 2 de 2
    • Remove the battery compartment.
  28. Fujifilm X-M1 Disassembly: paso 28, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 28, imagen 2 de 2
    • Remove the four 2.6 mm Phillips screws from the LCD hinges.
    • Tilt the LCD away from the metal frame.
    • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
  29. Fujifilm X-M1 Disassembly: paso 29, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 29, imagen 2 de 2
    • Use two fingers to pull the ribbon through the hole in the metal frame.
    • Remove the LCD from the metal frame.
  30. Fujifilm X-M1 Disassembly: paso 30, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 30, imagen 2 de 2
    • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
  31. Fujifilm X-M1 Disassembly: paso 31, imagen 1 de 2 Fujifilm X-M1 Disassembly: paso 31, imagen 2 de 2
    • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
    • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
  32. Fujifilm X-M1 Disassembly: paso 32, imagen 1 de 3 Fujifilm X-M1 Disassembly: paso 32, imagen 2 de 3 Fujifilm X-M1 Disassembly: paso 32, imagen 3 de 3
    • Use a plastic opening tool to pry the LCD case open.
    • Once the case is open, pull the ribbon through the hole on the back case.
  33. Fujifilm X-M1 Disassembly: paso 33, imagen 1 de 1
    • Remove the LCD from the screen cover.
  34. Fujifilm X-M1 Disassembly: paso 34, imagen 1 de 1
    • You have successfully disassembled the Fujifilm X-M1!
Conclusión
7 personas más completaron esta guía.
Kelsea Weber
Miembro Desde 11/12/15
20,047 Reputación
32 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,077 Guías creadas
7 comentarios
what about the top plate??? no one apparently knows how to remove the rotary switches from the upper assembly. Still looking for someone to show how those things are assembled
Juan Paz - Contestar
Hi, I have disassembled in more detail the whole camera and collected in reverse order to every detail , I can send you my photos for a complete collection of disassembly of the camera, my email: tyapa141465@mail.ru
Felus Felus - Contestar
Great article.
I have disassembled mine in order to clean dust inside sensor assembly, i took apart #26 using top 2 screws and the bottom one.
Unfortuntatly in the middle there were spacers, on the bottom 3 of them, on the upper side i have found 5 little metal spacers… without knowing how many were on the left, and on the right. Do you have pictures of this stage? Tya.
Francesco - Contestar
Большое спасибо автору статьи. Благодаря ей разобрали Fuji X-A2 для ремонта (после падения камеры не работала часть функций). После разборки и последующей сборки камера работает как новая. Только черную пленку под LCD пришлось выбросить, потому что она одноразовая
Lena Raigorodskiy - Contestar
Many thanks to the author of the article. Thanks to her dismantled Fuji X-A2 for repair (after the fall of the camera did not work part of the functions). After disassembly and subsequent Assembly, the camera works as new. Only the black film under the LCD had to be thrown away, because it is disposable
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 29
Ultimos 30 días: 111
Todo El Tiempo: 12,051
