Saltar al contenido principal
Fujifilm Finepix S1800 Back Cover Assembly Replacement
Qué necesitas
  1. Fujifilm Finepix S1800 Back Cover Assembly Replacement, Back Cover Assembly: paso 1, imagen 1 de 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Back Cover Assembly Replacement: paso 2, imagen 1 de 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Back Cover Assembly Replacement: paso 3, imagen 1 de 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Back Cover Assembly Replacement: paso 4, imagen 1 de 2 Fujifilm Finepix S1800 Back Cover Assembly Replacement: paso 4, imagen 2 de 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
Conclusión
Una persona más ha completado esta guía.
Ryan Rockford
Miembro Desde 02/15/17
618 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 8-6, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 380
