Saltar al contenido principal
Fujifilm Finepix S1000fd Leather Grip Replacement
Qué necesitas
  1. Fujifilm Finepix S1000fd Leather Grip Replacement, Rear Cover Casing: paso 1, imagen 1 de 2 Fujifilm Finepix S1000fd Leather Grip Replacement, Rear Cover Casing: paso 1, imagen 2 de 2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Leather Grip Replacement: paso 2, imagen 1 de 2 Fujifilm Finepix S1000fd Leather Grip Replacement: paso 2, imagen 2 de 2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Leather Grip Replacement: paso 3, imagen 1 de 1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Leather Grip Replacement, Leather Grip: paso 4, imagen 1 de 1
    • Using the metal spudger, place it in between the leather grip and the black plastic compartment
  5. Fujifilm Finepix S1000fd Leather Grip Replacement: paso 5, imagen 1 de 1
    • Repeat Step 4 for the other side
    • Remove the leather grip
Conclusión
Lizzie Eller
Miembro Desde 01/25/17
422 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-7, Banghart Winter 2017 Miembro de Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 479
