Saltar al contenido principal
Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement
Qué necesitas
  1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: paso 2, imagen 1 de 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: paso 3, imagen 1 de 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: paso 4, imagen 1 de 3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: paso 4, imagen 2 de 3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: paso 4, imagen 3 de 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: paso 5, imagen 1 de 2 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: paso 5, imagen 2 de 2
    • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
  6. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: paso 6, imagen 1 de 1
    • Remove lens data cable by gently pulling it out.
  7. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: paso 7, imagen 1 de 1
    • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
Conclusión
Una persona más ha completado esta guía.
Sarah Looper
Miembro Desde 03/11/13
100 Reputación
7 Guías creadas
Equipo
Clemson, Team 13-4, Benson Spring 2013 Miembro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 828
