Saltar al contenido principal
Fujifilm Finepix F10 6.3 MP Flash Battery Replacement
Qué necesitas
  1. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 2, imagen 1 de 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 3, imagen 1 de 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 4, imagen 1 de 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 4, imagen 2 de 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 4, imagen 3 de 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Front cover: paso 5, imagen 1 de 1
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 6, imagen 1 de 1
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 7, imagen 1 de 2 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: paso 7, imagen 2 de 2
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: paso 8, imagen 1 de 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: paso 8, imagen 2 de 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: paso 8, imagen 3 de 3
    • Gently remove battery from casing.
Conclusión
Una persona más ha completado esta guía.
Sarah Looper
Miembro Desde 03/11/13
100 Reputación
7 Guías creadas
Equipo
Clemson, Team 13-4, Benson Spring 2013 Miembro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Miembros
16 Guías creadas
Un comentario
What is the battery number so you can have a replacement ready?
attic77 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 697
