Saltar al contenido principal
Fujifilm FinePix Z5 Optical Lens Replacement
Qué necesitas
  1. Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: paso 1, imagen 1 de 3 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: paso 1, imagen 2 de 3 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: paso 1, imagen 3 de 3
    • Remove the two screws from the right side of the camera and the two screws from the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 Optical Lens Replacement: paso 2, imagen 1 de 1
    • Remove the three screws from the bottom of the camera.
    • Use a three-prong screwdriver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 Optical Lens Replacement: paso 3, imagen 1 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 3, imagen 2 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 3, imagen 3 de 3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 Optical Lens Replacement: paso 4, imagen 1 de 2 Fujifilm FinePix Z5 Optical Lens Replacement: paso 4, imagen 2 de 2
    • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
    • There is an orange ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 Optical Lens Replacement: paso 5, imagen 1 de 2 Fujifilm FinePix Z5 Optical Lens Replacement: paso 5, imagen 2 de 2
    • Using a plastic opening tool to flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 Optical Lens Replacement: paso 6, imagen 1 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 6, imagen 2 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 6, imagen 3 de 3
    • Remove the two screws that are holding the silver paneling on.
    • There is a gold foil which will tear upon removal of the silver paneling, this is normal.
    • Remove the screw anchoring the motherboard on the right.
  7. Fujifilm FinePix Z5 Optical Lens Replacement: paso 7, imagen 1 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 7, imagen 2 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 7, imagen 3 de 3
    • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
    • Detach the gold ribbon cable on the top middle of the camera as well.
  8. Fujifilm FinePix Z5 Optical Lens Replacement: paso 8, imagen 1 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 8, imagen 2 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 8, imagen 3 de 3
    • Hold wires on the left with an index finger, to keep them out of the way.
    • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
    • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
  9. Fujifilm FinePix Z5 Optical Lens Replacement: paso 9, imagen 1 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 9, imagen 2 de 3 Fujifilm FinePix Z5 Optical Lens Replacement: paso 9, imagen 3 de 3
    • Lift the lens off of the camera base (there is nothing anchoring it down).
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 812
