Saltar al contenido principal
Fujifilm FinePix Z5 LCD Screen Replacement
Qué necesitas
  1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: paso 1, imagen 3 de 3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 LCD Screen Replacement: paso 2, imagen 1 de 2 Fujifilm FinePix Z5 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 LCD Screen Replacement: paso 3, imagen 1 de 3 Fujifilm FinePix Z5 LCD Screen Replacement: paso 3, imagen 2 de 3 Fujifilm FinePix Z5 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 LCD Screen Replacement: paso 4, imagen 1 de 2 Fujifilm FinePix Z5 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 LCD Screen Replacement: paso 5, imagen 1 de 2 Fujifilm FinePix Z5 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
Conclusión
Kyle Kaczmar
Miembro Desde 02/10/12
14 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 964
