Saltar al contenido principal
Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
  2. Fujifilm FinePix Z1 Battery Replacement: paso 2, imagen 1 de 1
    • Turn the camera to the bottom and find the battery access door on the left side.
  3. Fujifilm FinePix Z1 Battery Replacement: paso 3, imagen 1 de 2 Fujifilm FinePix Z1 Battery Replacement: paso 3, imagen 2 de 2
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
  4. Fujifilm FinePix Z1 Battery Replacement: paso 4, imagen 1 de 1
    • Push the yellow tab to eject the battery.
  5. Fujifilm FinePix Z1 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery and replace with a new one.
Conclusión
Carra
Miembro Desde 01/30/18
533 Reputación
4 Guías creadas
Equipo
Baylor, Team S2-G4, Johnson Spring 2018 Miembro de Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 718
