Saltar al contenido principal
Fujifilm FinePix XP80 Shutter Button Replacement
Qué necesitas
  1. Fujifilm FinePix XP80  Shutter Button Replacement, Battery: paso 1, imagen 1 de 3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: paso 1, imagen 2 de 3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: paso 1, imagen 3 de 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80  Shutter Button Replacement: paso 2, imagen 1 de 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80  Shutter Button Replacement, Exterior Case: paso 3, imagen 1 de 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80  Shutter Button Replacement: paso 4, imagen 1 de 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80  Shutter Button Replacement: paso 5, imagen 1 de 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80  Shutter Button Replacement: paso 6, imagen 1 de 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80  Shutter Button Replacement: paso 7, imagen 1 de 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80  Shutter Button Replacement: paso 8, imagen 1 de 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80  Shutter Button Replacement: paso 9, imagen 1 de 2 Fujifilm FinePix XP80  Shutter Button Replacement: paso 9, imagen 2 de 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: paso 10, imagen 1 de 2 Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: paso 10, imagen 2 de 2
    • Once the exterior case is removed, separate the plastic depressor to ensure there is nothing lodged in or around the button, preventing proper functionality.
Conclusión
Una persona más ha completado esta guía.
Daniela Pesci
Miembro Desde 09/28/16
194 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-3, Cagle Fall 2016 Miembro de USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Miembros
14 Guías creadas
2 comentarios
Do you know where I can get replacement shutter button parts for this camera.
DEAN MURPHY - Contestar
Where can I buy the shutter button components for this camera?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 745
