Saltar al contenido principal
Fujifilm FinePix XP70 Front and Back Panel Replacement
Qué necesitas
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 2, imagen 1 de 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 2, imagen 2 de 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 3, imagen 1 de 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: paso 4, imagen 1 de 1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 5, imagen 1 de 1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 6, imagen 1 de 1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 7, imagen 1 de 1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 8, imagen 1 de 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 8, imagen 2 de 2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 9, imagen 1 de 1
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 10, imagen 1 de 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 10, imagen 2 de 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: paso 10, imagen 3 de 3
    • Pry the back plate off with a plastic opening tool
Conclusión
Olivia A
Miembro Desde 10/24/16
484 Reputación
4 Guías creadas
Equipo
Un comentario
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 391
