Saltar al contenido principal
Fujifilm FinePix XP70 Button Replacement
Qué necesitas
  1. Fujifilm FinePix XP70 Button Replacement, Battery: paso 1, imagen 1 de 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Button Replacement: paso 2, imagen 1 de 2 Fujifilm FinePix XP70 Button Replacement: paso 2, imagen 2 de 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Button Replacement: paso 3, imagen 1 de 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Button Replacement, Button: paso 4, imagen 1 de 2 Fujifilm FinePix XP70 Button Replacement, Button: paso 4, imagen 2 de 2
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP70 Button Replacement: paso 5, imagen 1 de 1
    • Pull the three buttons out.
Conclusión
Olivia A
Miembro Desde 10/24/16
484 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 277
