Qué necesitas
Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
Using your Philips head screwdriver remove the screws from the metal shield.
Remove the metal shield.
Find the speaker and gently pull away from the motherboard. It is just on by an adhesive.
Identify where the speaker is connected to the motherboard and unsolder both of the connections,
Guide for Soldering: Cómo soldar y desoldar conexiones
