Qué necesitas
Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
Unsolder the connections shown in the image that connect the black, pink, and blue wires to the bulb.
Soldering Guide: Cómo soldar y desoldar conexiones
Casi Terminas!
Conclusión
