Saltar al contenido principal
Fujifilm FinePix S8630 Button Panel Replacement
Qué necesitas
  1. Fujifilm FinePix S8630 Button Panel Replacement, Battery Door: paso 1, imagen 1 de 1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Button Panel Replacement: paso 2, imagen 1 de 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Button Panel Replacement: paso 3, imagen 1 de 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Button Panel Replacement: paso 4, imagen 1 de 2 Fujifilm FinePix S8630 Button Panel Replacement: paso 4, imagen 2 de 2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Button Panel Replacement: paso 5, imagen 1 de 1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Button Panel Replacement: paso 6, imagen 1 de 3 Fujifilm FinePix S8630 Button Panel Replacement: paso 6, imagen 2 de 3 Fujifilm FinePix S8630 Button Panel Replacement: paso 6, imagen 3 de 3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Button Panel Replacement: paso 7, imagen 1 de 3 Fujifilm FinePix S8630 Button Panel Replacement: paso 7, imagen 2 de 3 Fujifilm FinePix S8630 Button Panel Replacement: paso 7, imagen 3 de 3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: paso 8, imagen 1 de 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: paso 8, imagen 2 de 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: paso 8, imagen 3 de 3
    • Take the back casing and push the button panel out gently. The panel will easily fall out and can easily be replaced.
Conclusión
Equipo
USF Tampa, Team 3-2, Sullivan Spring 2016 Miembro de USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 377
