Saltar al contenido principal
Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: paso 1, imagen 1 de 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: paso 2, imagen 1 de 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: paso 3, imagen 1 de 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
Conclusión
Insert your new batteries, close the battery chamber, and you're done!
Greg Sweeney
Miembro Desde 01/14/15
137 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 7-1, Remmell Winter 2015 Miembro de USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
Miembros de 4
9 Guías creadas
3 comentarios
should there be an indicator led to show the camera is charing ?
tony smith - Contestar
should the camera indicate that it is being charged ?
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 28
Todo El Tiempo: 1,944
