Saltar al contenido principal
Fujifilm FinePix S4200 Viewfinder Replacement
Qué necesitas
  1. Fujifilm FinePix S4200 Viewfinder  Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Turn the camera off.
    • Turn the camera upside down so that the battery compartment is showing.
  2. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 2, imagen 1 de 1
    • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
  3. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 3, imagen 1 de 1
    • Rotate camera to the side where the speaker ports are located.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  4. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 4, imagen 1 de 1
    • Turn the camera to the opposite side where the HDMI port is located.
    • Remove all five 4 mm screws with a Phillips #000 screwdriver.
  5. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 5, imagen 1 de 3 Fujifilm FinePix S4200 Viewfinder  Replacement: paso 5, imagen 2 de 3 Fujifilm FinePix S4200 Viewfinder  Replacement: paso 5, imagen 3 de 3
    • Casing is fragile.
    • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
    • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
  6. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 6, imagen 1 de 1
    • Use force to pull apart the back casing from the camera.
  7. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 7, imagen 1 de 1
    • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
  8. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 8, imagen 1 de 2 Fujifilm FinePix S4200 Viewfinder  Replacement: paso 8, imagen 2 de 2
    • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
    • Flip over LCD screen so that the left side of the metal plate is visible.
  9. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 9, imagen 1 de 1
    • Rotate the camera vertically so that it is easier to manage.
    • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
  10. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 10, imagen 1 de 1
    • Detach the metal plate from the motherboard.
  11. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 11, imagen 1 de 2 Fujifilm FinePix S4200 Viewfinder  Replacement: paso 11, imagen 2 de 2
    • The orange ribbon cable is fragile.
    • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
    • Gently remove the LCD screen from the motherboard.
  12. Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: paso 12, imagen 1 de 2 Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: paso 12, imagen 2 de 2
    • Remove the two 4 mm screws with a Phillips 000 screwdriver under the viewfinder.
  13. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 13, imagen 1 de 1
    • Carefully pull off the plastic cover from the view finder.
  14. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 14, imagen 1 de 1
    • Remove the two 3mm screws surrounding the viewfinder with a Phillips 000 screwdriver.
  15. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 15, imagen 1 de 1
    • Orange ribbon is fragile.
    • Using the plastic opening tool, pull down the small black latch to remove the orange ribbon from the mother board.
  16. Fujifilm FinePix S4200 Viewfinder  Replacement: paso 16, imagen 1 de 1
    • Pull the viewfinder up to remove it from the body of the camera
Conclusión
2 personas más completaron esta guía.
Equipo
CSU Fullerton, Team 1-4, Bruce Fall 2015 Miembro de CSU Fullerton, Team 1-4, Bruce Fall 2015
CSUF-BRUCE-F15S1G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 893
