Saltar al contenido principal
Fujifilm FinePix S4200 Motherboard Replacement
Qué necesitas
  1. Fujifilm FinePix S4200 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Turn off the camera by pushing the switch as shown.
  2. Fujifilm FinePix S4200 Motherboard Replacement: paso 2, imagen 1 de 3 Fujifilm FinePix S4200 Motherboard Replacement: paso 2, imagen 2 de 3 Fujifilm FinePix S4200 Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove all the 4mm screws from the left, right, and bottom of the camera.
    • A Phillips #000 screwdriver should be used to remove all nine screws.
  3. Fujifilm FinePix S4200 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove casing part pictured by gently pulling up until casing is fully detached.
  4. Fujifilm FinePix S4200 Motherboard Replacement: paso 4, imagen 1 de 3 Fujifilm FinePix S4200 Motherboard Replacement: paso 4, imagen 2 de 3 Fujifilm FinePix S4200 Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
    • Use the Phillips #000 screwdriver to avoid stripping the screws.
  5. Fujifilm FinePix S4200 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the top casing by pulling upwards.
    • To remove orange tab gently pull on the tab until it is detached from the clamping device on the motherboard.
  6. Fujifilm FinePix S4200 Motherboard Replacement: paso 6, imagen 1 de 2 Fujifilm FinePix S4200 Motherboard Replacement: paso 6, imagen 2 de 2
    • Carefully remove LCD screen.
    • Gently pull on orange tab until it is free.
    • This orange strip is susceptible to tearing.
  7. Fujifilm FinePix S4200 Motherboard Replacement: paso 7, imagen 1 de 2 Fujifilm FinePix S4200 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove remaining 4mm screw.
    • Detach metal plate by lifting plate upwards.
  8. Fujifilm FinePix S4200 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove remaining orange tabs on motherboard. Gently pull on each orange tab until it is free. Make sure all tabs are free (check markers on image).
  9. Fujifilm FinePix S4200 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the 4mm screws in the corners of the motherboard.
  10. Fujifilm FinePix S4200 Motherboard Replacement: paso 10, imagen 1 de 1
    • Use a soldering iron to melt the solder and disconnect the five connections shown.
    • After removing the soldered connections, they must be given ample time to cool before moving to the next step.
  11. Fujifilm FinePix S4200 Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
  12. Fujifilm FinePix S4200 Motherboard Replacement: paso 12, imagen 1 de 1
    • Replace the old motherboard with a new motherboard.
  13. Fujifilm FinePix S4200 Motherboard Replacement: paso 13, imagen 1 de 1
    • Reconnect the orange strips to their designated connections.
    • Be gentle when reconnecting the orange strips as they are susceptible to tearing.
  14. Fujifilm FinePix S4200 Motherboard Replacement: paso 14, imagen 1 de 1
    • Resolder all the connections and wire onto the new motherboard
    • After soldering the connections, they must be given ample time to cool before moving to the next step.
    • After given enough time and all the connections on new motherboard are secured, reassemble the camera.
Conclusión
Equipo
IUPUI, Team S1-G5, Harley Fall 2018 Miembro de IUPUI, Team S1-G5, Harley Fall 2018
IUPUI-HARLEY-F18S1G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 31
Todo El Tiempo: 585
