Saltar al contenido principal
Fujifilm FinePix S1 EVF/LCD Button Replacement
Qué necesitas
  1. Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: paso 1, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: paso 1, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: paso 1, imagen 3 de 3
    • Remove the 7 screws on the perimeter of the camera body.
  2. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 2, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 2, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 2, imagen 3 de 3
    • Remove the flash accessory cap.
    • Remove the spacer covering the screws under the flash accessory cap.
  3. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 3, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 3, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 3, imagen 3 de 3
    • Remove the 4 screws from the inside of the flash accessory slot.
    • Pull off the flash accessory slot.
  4. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 4, imagen 1 de 2 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 4, imagen 2 de 2
    • Remove the screw from LCD Screen hinge cover.
    • Remove the LCD Screen hinge cover.
  5. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 5, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 5, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 5, imagen 3 de 3
    • Remove the 3 screws located on the LCD screen hinge.
    • Remove the caps from both ends of the LCD screen hinge by lifting them off.
  6. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 6, imagen 1 de 1
    • Remove the 2 screws from under the LCD hinge caps.
  7. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 7, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 7, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 7, imagen 3 de 3
    • Pry apart the back body from the rest of the camera.
  8. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 8, imagen 1 de 2 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 8, imagen 2 de 2
    • Carefully pull the back body off of the camera.
    • Make sure to not yank off the connections from the body to the motherboard.
  9. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 9, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 9, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 9, imagen 3 de 3
    • Use a spudger to lift up on the tab, releasing the yellow wire strip.
    • Use a spudger to lift up on the side tab, releasing the blue wire connection.
  10. Fujifilm FinePix S1 EVF/LCD Button Replacement, EVF/LCD Button Cover: paso 10, imagen 1 de 1
    • Remove 2 screws from back of EVF/LCD button.
  11. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 11, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 11, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 11, imagen 3 de 3
    • Pull EVF/LCD button frame out from the camera casing.
  12. Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 12, imagen 1 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 12, imagen 2 de 3 Fujifilm FinePix S1 EVF/LCD Button Replacement: paso 12, imagen 3 de 3
    • Pull button cover off of the button frame.
Conclusión
Equipo
USF Tampa, Team 3-6, Sullivan Spring 2016 Miembro de USF Tampa, Team 3-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 1,069
