Introducción
This guides is meant to be used with the intention to replace the lens.
Warning: The lens is very fragile; any scrape or fingerprint could result in a unusable lens. Take great caution in the replacement of the lens.
Qué necesitas
Flip the camera so that the bottom is facing upwards.
With the Phillips #00 screwdriver, remove all four screws.
Slowly and carefully pull the frame away to have a better view of the inside.
Once the motherboard is taken out, with a screwdriver, unscrew all highlighted screws.
Take the lens off once it is unscrewed.
3 personas más completaron esta guía.
