Saltar al contenido principal
Fujifilm FinePix HS30EXR Frame Replacement
Qué necesitas
  1. Fujifilm FinePix HS30EXR Frame Replacement, Frame: paso 1, imagen 1 de 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Frame Replacement: paso 2, imagen 1 de 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Frame Replacement: paso 3, imagen 1 de 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Frame Replacement: paso 4, imagen 1 de 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Frame Replacement: paso 5, imagen 1 de 1
  6. Fujifilm FinePix HS30EXR Frame Replacement: paso 6, imagen 1 de 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Frame Replacement: paso 7, imagen 1 de 2 Fujifilm FinePix HS30EXR Frame Replacement: paso 7, imagen 2 de 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
Conclusión
Andrew Scouten
Miembro Desde 10/22/18
838 Reputación
5 Guías creadas
Equipo
Baylor, Team S1-G2, Williams Fall 2018 Miembro de Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 712
