Saltar al contenido principal
Fujifilm FinePix HS30EXR Discharge Flash Replacement
Qué necesitas
  1. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Frame: paso 1, imagen 1 de 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 2, imagen 1 de 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 3, imagen 1 de 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 4, imagen 1 de 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 5, imagen 1 de 1
  6. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 6, imagen 1 de 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 7, imagen 1 de 2 Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 7, imagen 2 de 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Motherboard: paso 8, imagen 1 de 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 9, imagen 1 de 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 10, imagen 1 de 1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 11, imagen 1 de 1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 12, imagen 1 de 1
  13. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 13, imagen 1 de 1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 14, imagen 1 de 1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Discharge Flash Replacement: paso 15, imagen 1 de 1
    • Remove the motherboard.
  16. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Discharge Flash: paso 16, imagen 1 de 1
    • Remove the discharge flash by giving it a light tug. It is held in place with glue.
    • Replace the old flash bulb with a new one, and begin the reconstruction of the device.
Conclusión
Una persona más ha completado esta guía.
Haden Calvert
Miembro Desde 10/22/18
100 Reputación
1 Guía escrita
Equipo
Baylor, Team S1-G2, Williams Fall 2018 Miembro de Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 660
