Saltar al contenido principal
Introducción
This guide is meant to be used with the intention to replace the battery.
Warning: Ensure that the battery is not so damaged that it would inflict user harm upon replacement. Do not forget to properly dispose of the old battery once it is replaced.
Herramientas
No se especificaron herramientas.
Partes
  1. To gain access to the battery, flip the camera so that is upside down.
    • To gain access to the battery, flip the camera so that is upside down.
    • Pull on the lever while at the same time pulling outwards, away from the device.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Open the battery compartment.
    • Open the battery compartment.
    • Pull the grey lever towards the device; this should dislodge the battery from the compartment.
  4. Pull the battery out of the compartment, and replace it with a newly functional battery.
    • Pull the battery out of the compartment, and replace it with a newly functional battery.
Conclusión
Andrew Scouten
Miembro Desde 22/10/18
637 Reputación
5 Guías creadas
Equipo
Baylor, Team S1-G2, Williams Fall 2018 Miembro de Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 79
