Introducción
In this guide it will be outlined on how to replace or disassemble an LCD screen display. A LCD screen usually needs to be replaced if it is not displaying the right coloration on the screen for example a yellowish tint. A LCD screen can also be replaced if it does not show anything at all.
Qué necesitas
Hold the camera with the lens facing towards youself.
Turn the camera upside down and place your right thumb on the battery chamber cover.
Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
With the LCD monitor facing upwards, use the tweezers to lift the ribbon clamp which will release the grip on the ribbon.
