Saltar al contenido principal
Fujifilm FinePix F505EXR Battery Replacement
Qué necesitas
  1. Fujifilm FinePix F505EXR Battery Replacement, Battery: paso 1, imagen 1 de 2 Fujifilm FinePix F505EXR Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Battery Replacement: paso 2, imagen 1 de 2 Fujifilm FinePix F505EXR Battery Replacement: paso 2, imagen 2 de 2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Battery Replacement: paso 3, imagen 1 de 2 Fujifilm FinePix F505EXR Battery Replacement: paso 3, imagen 2 de 2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 998
