Saltar al contenido principal
Fujifilm FinePix AX665 Lens Housing Replacement
Qué necesitas
  1. Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: paso 1, imagen 1 de 3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: paso 1, imagen 2 de 3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: paso 1, imagen 3 de 3
    • Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
  2. Fujifilm FinePix AX665 Lens Housing Replacement: paso 2, imagen 1 de 3 Fujifilm FinePix AX665 Lens Housing Replacement: paso 2, imagen 2 de 3 Fujifilm FinePix AX665 Lens Housing Replacement: paso 2, imagen 3 de 3
    • Use a plastic pick to separate each side of the camera case apart.
  3. Fujifilm FinePix AX665 Lens Housing Replacement: paso 3, imagen 1 de 2 Fujifilm FinePix AX665 Lens Housing Replacement: paso 3, imagen 2 de 2
    • Remove the ribbon cable from the side of the logic board.
  4. Fujifilm FinePix AX665 Lens Housing Replacement: paso 4, imagen 1 de 2 Fujifilm FinePix AX665 Lens Housing Replacement: paso 4, imagen 2 de 2
    • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
  5. Fujifilm FinePix AX665 Lens Housing Replacement: paso 5, imagen 1 de 2 Fujifilm FinePix AX665 Lens Housing Replacement: paso 5, imagen 2 de 2
    • Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
  6. Fujifilm FinePix AX665 Lens Housing Replacement: paso 6, imagen 1 de 1
    • Remove the three screws holding the sensor.
  7. Fujifilm FinePix AX665 Lens Housing Replacement: paso 7, imagen 1 de 1
    • Remove the sensor ribbon cable from the logic board.
  8. Fujifilm FinePix AX665 Lens Housing Replacement: paso 8, imagen 1 de 1
    • Remove the lens housing ribbon cable.
  9. Fujifilm FinePix AX665 Lens Housing Replacement: paso 9, imagen 1 de 1
    • Remove the lens housing by moving the gray clip holding the unit.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 302
