Saltar al contenido principal
Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement
Qué necesitas
  1. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement, Lens Assembly and Gears: paso 1, imagen 1 de 3 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement, Lens Assembly and Gears: paso 1, imagen 2 de 3 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement, Lens Assembly and Gears: paso 1, imagen 3 de 3
    • Use a #00 screwdriver to remove all six screws holding the camera case together.
  2. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 2, imagen 1 de 3 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 2, imagen 2 de 3 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 2, imagen 3 de 3
    • Use a plastic pick to separate the two sections of the camera.
  3. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 3, imagen 1 de 2 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 3, imagen 2 de 2
    • Remove the ribbon cable from the side of logic board.
  4. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 4, imagen 1 de 2 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 4, imagen 2 de 2
    • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
  5. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 5, imagen 1 de 2 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 5, imagen 2 de 2
    • Carefully flip the screen, lift the narrow black latch that retains the ribbon cable and remove the ribbon cable attaching it to the logic board.
  6. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 6, imagen 1 de 1
    • Remove the three screws holding the sensor.
  7. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 7, imagen 1 de 1
    • Carefully peel off the black rubber tape covering the sensor ribbon cable connector on the logic board, lift the narrow black latch that retains the ribbon cable and remove the sensor ribbon cable from the logic board.
  8. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 8, imagen 1 de 1
    • Lift the narrow black latch that retains the lens housing ribbon cable and remove the lens housing ribbon cable.
  9. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 9, imagen 1 de 1
    • Remove the lens housing by moving the gray clip holding the unit.
  10. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 10, imagen 1 de 3 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 10, imagen 2 de 3 Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 10, imagen 3 de 3
    • Remove the three screws holding the cover of the lens housing.
    • Carefully remove the lens housing top cover.
  11. Fujifilm FinePix AX665 Lens Assembly and Gears Replacement Replacement: paso 11, imagen 1 de 1
    • Inspect all the gears and make sure they are functioning correctly.
    • Replace the gears as needed.
Conclusión
2 personas más completaron esta guía.
2Guía Comentarios
I used this guide to access the lens motor on a Fuji FinePix AX350 since it was the closest guide to my camera (lens was stuck in the open position and removing/replacing batteries to not solve the issue). There are a few small differences between the two cameras: the AX350's LCD bracket has a retaining screw in addition to the clips; also, the AX350's lens housing cover has two additional retaining screws.
The lens's main gear train was OK, so I drove the motor forward & backward using a 3V DC supply to free up the lens retraction/extension mechanism.
The only issue I had with this guide is that it was not clear the the LCD, Sensor & Lens Ribbon Cable connectors have flip-up latches and the flip-up latch on the Sensor Ribbon Cable is under an adhesive strip.
charlescacc - Contestar
can you help me on finepixe jv 500?
Q_pl - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 30
Todo El Tiempo: 1,114
