Saltar al contenido principal
Fujifilm FinePix A350 Battery Contact Replacement
Qué necesitas
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: paso 1, imagen 1 de 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: paso 1, imagen 2 de 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: paso 1, imagen 3 de 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: paso 2, imagen 1 de 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: paso 2, imagen 2 de 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: paso 2, imagen 3 de 3
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Conclusión
Jaxon Cramer
Miembro Desde 03/21/16
1,045 Reputación
9 Guías creadas
Equipo
Clemson, Team 6-4, Benson Spring 2016 Miembro de Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Miembros
17 Guías creadas
Un comentario
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 494
