Saltar al contenido principal
Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement
Qué necesitas
  1. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: paso 1, imagen 1 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: paso 1, imagen 2 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: paso 1, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 2, imagen 1 de 1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 3, imagen 1 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 3, imagen 2 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 3, imagen 3 de 3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 4, imagen 1 de 2 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 4, imagen 2 de 2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 5, imagen 1 de 1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
  6. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Button Circuit Board: paso 6, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the two screws on the bracket holding the right side of the button circuit board.
    • One 3.85mm Phillips #00 screw
    • One 3.4mm Phillips #00 screw
  7. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 7, imagen 1 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 7, imagen 2 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 7, imagen 3 de 3
    • Use your fingers to remove the metal bracket and brown colored film.
  8. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 8, imagen 1 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 8, imagen 2 de 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: paso 8, imagen 3 de 3
    • Use the spudger to pry up the clear plastic tab.
    • Pull the button receiver, button circuit board, and swivel button out as a single unit.
    • Jiggle the swivel button out of place if necessary.
Conclusión
Sarah Daliva
Miembro Desde 04/04/12
14 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-8, Forte Spring 2012 Miembro de Cal Poly, Team 14-8, Forte Spring 2012
CPSU-FORTE-S12S14G8
5 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 1,346
