Qué necesitas
Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
Four 3.95mm Phillips screws located on the bottom of the camera
Two 3.95mm Phillips screws located on the right side of the camera
One 3.95mm Phillips screw located on the left side of the camera
Wedge the edge of the spudger between the front and back case, near the corner of the flash.
Carefully run the spudger along the right edge of the camera, creating an opening.
Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
