Saltar al contenido principal
Fujifilm Fine S1800 LCD Screen Replacement
Qué necesitas
  1. Fujifilm Fine S1800 LCD Screen Replacement, Back Cover Assembly: paso 1, imagen 1 de 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Fine S1800 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Fine S1800 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Fine S1800 LCD Screen Replacement: paso 4, imagen 1 de 2 Fujifilm Fine S1800 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 2 Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: paso 5, imagen 2 de 2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Fine S1800 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Fine S1800 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
Conclusión
Ryan Rockford
Miembro Desde 02/15/17
618 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 8-6, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 556
