Saltar al contenido principal
Fujifilm Endeavor 100ix Film Door Replacement
Qué necesitas
  1. Fujifilm Endeavor 100ix Film Door Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Film Door Replacement: paso 2, imagen 1 de 1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Film Door Replacement: paso 3, imagen 1 de 1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Fujifilm Endeavor 100ix Film Door Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Fujifilm Endeavor 100ix Film Door Replacement: paso 5, imagen 1 de 1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Film Door Replacement: paso 6, imagen 1 de 2 Fujifilm Endeavor 100ix Film Door Replacement: paso 6, imagen 2 de 2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Fujifilm Endeavor 100ix Film Door Replacement: paso 7, imagen 1 de 1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Fujifilm Endeavor 100ix Film Door Replacement: paso 8, imagen 1 de 1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Fujifilm Endeavor 100ix Film Door Replacement: paso 9, imagen 1 de 1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Fujifilm Endeavor 100ix Film Door Replacement: paso 10, imagen 1 de 1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Fujifilm Endeavor 100ix Film Door Replacement: paso 11, imagen 1 de 2 Fujifilm Endeavor 100ix Film Door Replacement: paso 11, imagen 2 de 2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
  12. Fujifilm Endeavor 100ix Film Door Replacement, Film Door: paso 12, imagen 1 de 1
    • Locate the film door on the bottom of the camera.
    • Locate the pin that connects the film door to the camera
  13. Fujifilm Endeavor 100ix Film Door Replacement: paso 13, imagen 1 de 1
    • Push the pin from one side with the spudger until it comes out on the opposite side.
  14. Fujifilm Endeavor 100ix Film Door Replacement: paso 14, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grab the pin with the tweezers and gently pull it out.
    • The film door should feel lose.
  15. Fujifilm Endeavor 100ix Film Door Replacement: paso 15, imagen 1 de 1
    • Remove the door with your fingers and discard it.
    • Insert the replacement film door appropriately to fit where the broken door was located.
Conclusión
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
Eric Nicolai
Miembro Desde 01/10/11
679 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-5, Forte Winter 2011 Miembro de Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,770
