Saltar al contenido principal
FujiFilm FinePix S4500 LCD Replacement
Qué necesitas
  1. FujiFilm FinePix S4500 LCD Replacement, LCD: paso 1, imagen 1 de 1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 LCD Replacement: paso 2, imagen 1 de 1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 LCD Replacement: paso 3, imagen 1 de 1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 LCD Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 LCD Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 LCD Replacement: paso 6, imagen 1 de 2 FujiFilm FinePix S4500 LCD Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 LCD Replacement: paso 7, imagen 1 de 1
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 LCD Replacement: paso 8, imagen 1 de 2 FujiFilm FinePix S4500 LCD Replacement: paso 8, imagen 2 de 2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
Conclusión
Una persona más ha completado esta guía.
Vicente Rios
Miembro Desde 01/25/17
708 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-4, Banghart Winter 2017 Miembro de Cal Poly, Team 9-4, Banghart Winter 2017
CPSU-BANGHART-W17S9G4
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 617
