Saltar al contenido principal
FujiFilm FinePix A340 LCD Screen Replacement
Qué necesitas
  1. FujiFilm FinePix A340 LCD Screen Replacement, Outer Case: paso 1, imagen 1 de 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 LCD Screen Replacement: paso 2, imagen 1 de 3 FujiFilm FinePix A340 LCD Screen Replacement: paso 2, imagen 2 de 3 FujiFilm FinePix A340 LCD Screen Replacement: paso 2, imagen 3 de 3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 LCD Screen Replacement: paso 3, imagen 1 de 2 FujiFilm FinePix A340 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Now that everything has been disconnected from the board, remove LCD screen.
Conclusión
Cody
Miembro Desde 04/18/10
47 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-11, Maness Spring 2010 Miembro de Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 6,103
