Introducción
This guide shows how to remove and replace the battery of the Fugoo Tough.
Qué necesitas
Begin by unscrewing the four 10.72mm corner screws using the Hex 2.0 screwdriver.
Using the Hex 1.5 screwdriver, remove the remaining six 5.79mm screws on the front of the speaker.
Pull the front part of shell away from the back part of shell.
Change to the h1.3 head. Remove all four 5.57mm screws on both speaker covers.
Pull on the speaker covers to remove them.
Rotate to side the speaker that has the charging port. Remove the four 5.57mm screws facing you.
Rotate the speaker 180 degrees and then remove the four 5.57 screws on the side speaker that has the power/bluetooth buttons.
9 comentarios
what are the battery specs? where can one be purchased?
Update: Success! Worked beautifully. I'll put together some pix I took to wrap it up. If you kinda put it together and test it but the bass is all gone, give it a squeeze. Bass doesn't really show back up til you put screws back in.
What battery did you get? 18650? maH?
