Introducción
Here's an easy step by step tutorial on removing and replacing the inner tube.
First, remove the front wheel from the frame by unscrewing the adjustable screw
Next, wedge tire tool below the bike wheel, right above the rim.
Once firmly in place, push the tire tool down towards the ground in order to create spacing between the tire and the rim.
Following this, grab the 2nd tire tool and place it into the gap you have created.
Slide the 2nd tool around the entire circumference of the tire, while holding the first in place, in order to dislodge the tire from the rim.
Pump a small amount of air into the new bike tube so that it is easier to work with.
Next, locate the hole in the bike rim and feed the valve through and into position.
Next, wrap the rest of the tubing over the rim comfortably, while making sure that no folds or creases form on the tube.
To reassemble your device, follow these instructions.
2 personas más completaron esta guía.
