Saltar al contenido principal
Frigidaire Gallery Water Filter Replacement
Qué necesitas
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: paso 1, imagen 1 de 1
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: paso 2, imagen 1 de 2 Frigidaire Gallery Water Filter Replacement: paso 2, imagen 2 de 2
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: paso 3, imagen 1 de 3 Frigidaire Gallery Water Filter Replacement: paso 3, imagen 2 de 3 Frigidaire Gallery Water Filter Replacement: paso 3, imagen 3 de 3
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: paso 4, imagen 1 de 1
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 28
Ultimos 30 días: 205
Todo El Tiempo: 5,035
