Saltar al contenido principal
Frigidaire FPBS2778UF5 Drawer Handle Replacement
Qué necesitas
  1. Frigidaire FPBS2778UF5 Drawer Handle Replacement, Drawer Handle: paso 1, imagen 1 de 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement, Drawer Handle: paso 1, imagen 2 de 2
    • This is what the handle looks like when it's loose or is about to fall off.
  2. Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 2, imagen 1 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 2, imagen 2 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 2, imagen 3 de 3
    • Remove the four screws (two on each side) from beneath the handle using an Allen key.
    • You might need to press the Allen key hard inside for it to unscrew (if loosened).
  3. Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 3, imagen 1 de 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 3, imagen 2 de 2
    • Make sure the nuts holding the handle are secure. Only use your hands to tighten them, as using a wrench might damage the fridge.
  4. Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 4, imagen 1 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 4, imagen 2 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 4, imagen 3 de 3
    • Ensure that the nuts are securely inside the handle. Keep them inside the entire time to make the process easier.
    • Make sure nothing is inside on both sides of the handle which may have been causing it to loosen up.
  5. Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 5, imagen 1 de 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 5, imagen 2 de 2
    • Clean the inside with cotton swabs to prevent future problems.
    • This step is optional.
  6. Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 6, imagen 1 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 6, imagen 2 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 6, imagen 3 de 3
    • Loosen the nuts on both sides until they are not seen inside.
    • This will keep the holder stable on the fridge when it's screwed in.
  7. Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 7, imagen 1 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 7, imagen 2 de 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 7, imagen 3 de 3
    • Correctly place the holder in the correct holes on both sides.
    • Hold the holder and press it firmly onto the fridge to keep it steady.
    • You may require another person for this step.
    • Start screwing it back in with the same Allen key.
  8. Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 8, imagen 1 de 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement: paso 8, imagen 2 de 2
    • Make sure the screws are tight.
Linea de Meta
Parth Gupta
Miembro Desde 01/09/24
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 71
