Saltar al contenido principal
Frigidaire FFET1222QS Light Bulb Replacement
Qué necesitas
  1. Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: paso 1, imagen 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: paso 1, imagen 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: paso 1, imagen 3 de 3
    • Make sure to unplug the fridge from the wall socket before proceeding.
  2. Frigidaire FFET1222QS Light Bulb Replacement: paso 2, imagen 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 2, imagen 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 2, imagen 3 de 3
    • Using two hands, remove the plastic latch that's covering the dead light bulb.
    • To remove the latch, place both of your thumbs on the front face of the latch. Then, with your thumbs slowly push/squeeze the face of the latch, until the latch comes off.
  3. Frigidaire FFET1222QS Light Bulb Replacement: paso 3, imagen 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 3, imagen 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 3, imagen 3 de 3
    • Slowly unscrew the dead bulb in the counterclockwise direction to remove it from the socket.
  4. Frigidaire FFET1222QS Light Bulb Replacement: paso 4, imagen 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 4, imagen 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 4, imagen 3 de 3
    • Get the new light bulb and screw it into the empty bulb socket clockwise.
  5. Frigidaire FFET1222QS Light Bulb Replacement: paso 5, imagen 1 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 5, imagen 2 de 3 Frigidaire FFET1222QS Light Bulb Replacement: paso 5, imagen 3 de 3
    • Plug the fridge back into the wall socket, then check if the light bulb is working.
  6. Frigidaire FFET1222QS Light Bulb Replacement: paso 6, imagen 1 de 2 Frigidaire FFET1222QS Light Bulb Replacement: paso 6, imagen 2 de 2
    • If the light bulb works, return the latch to its original position using your two hands.
    • When returning the latch make sure the latch’s front face is in the right direction.
    • Then slowly connect the latch to cover the new bulb and makes sure it is secured before closing the fridge door.
Conclusión
Daniel kenneth
Miembro Desde 09/12/21
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 89
Todo El Tiempo: 2,390
