Introducción
This guide will show you how to replace a burnt out light bulb in your Frigidaire CFEF3011TWA oven. Oven light bulbs are useful in that they light the oven cooking area and allow you to look inside the oven without opening the oven door and losing the trapped heat. You won't need anything other than an A15 Light Bulb in this replacement.
Before beginning, make sure your oven is turned off and disconnected from the wall outlet.
Qué necesitas
Linea de Meta
