Introducción
The rear wheel axle holds the rear wheels to the wheelchair and allows smooth operation of the wheelchair.
Before maintaining the Rear Wheel Axle, familiarize yourself with tools you will be using with the Free Wheelchair Mission Tools Maintenance Guide.
Qué necesitas
Attach the 19mm socket wrench to the head of the bolt in the middle of the wheel
With the other hand use the 19mm crescent wrench to hold the nut in place
While holding the 19mm crescent wrench in place, use socket wrench to unscrew the bolt
Remove the wheel from the axle
To reassemble the axle to the wheelchair, follow these instructions in reverse order.
Una persona más ha completado esta guía.
