Saltar al contenido principal
Framework Desktop Antennas Replacement
Qué necesitas
  1. Framework Desktop Antennas Replacement, Power down your Desktop: paso 1, imagen 1 de 2 Framework Desktop Antennas Replacement, Power down your Desktop: paso 1, imagen 2 de 2
    • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
  2. Framework Desktop Antennas Replacement, Remove the Handle: paso 2, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the Handle: paso 2, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the Handle: paso 2, imagen 3 de 3
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
  3. Framework Desktop Antennas Replacement, Remove the Top Panel screws: paso 3, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the Top Panel screws: paso 3, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the Top Panel screws: paso 3, imagen 3 de 3
    • Use your finger to lift up the two D-rings on the Top Panel screws.
  4. Framework Desktop Antennas Replacement: paso 4, imagen 1 de 3 Framework Desktop Antennas Replacement: paso 4, imagen 2 de 3 Framework Desktop Antennas Replacement: paso 4, imagen 3 de 3
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
  5. Framework Desktop Antennas Replacement: paso 5, imagen 1 de 3 Framework Desktop Antennas Replacement: paso 5, imagen 2 de 3 Framework Desktop Antennas Replacement: paso 5, imagen 3 de 3
    • Repeat the same procedure for the other Top Panel screw.
  6. Framework Desktop Antennas Replacement, Remove the Top Panel: paso 6, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the Top Panel: paso 6, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the Top Panel: paso 6, imagen 3 de 3
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
  7. Framework Desktop Antennas Replacement, Remove the Left Panel: paso 7, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the Left Panel: paso 7, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the Left Panel: paso 7, imagen 3 de 3
    • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
    • Remove the Left Panel.
  8. Framework Desktop Antennas Replacement, Lay down the Desktop: paso 8, imagen 1 de 2 Framework Desktop Antennas Replacement, Lay down the Desktop: paso 8, imagen 2 de 2
    • Lay down the Desktop on its side so the fan is facing upward.
  9. Framework Desktop Antennas Replacement, Disconnect the fan: paso 9, imagen 1 de 2 Framework Desktop Antennas Replacement, Disconnect the fan: paso 9, imagen 2 de 2
    • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
  10. Framework Desktop Antennas Replacement: paso 10, imagen 1 de 2 Framework Desktop Antennas Replacement: paso 10, imagen 2 de 2
    • If you aren't using an RGB fan, then skip this step.
    • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
  11. Framework Desktop Antennas Replacement, Remove the CPU fan screws: paso 11, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the CPU fan screws: paso 11, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
  12. Framework Desktop Antennas Replacement, Remove the fan duct: paso 12, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the fan duct: paso 12, imagen 2 de 2
    • Lift the fan duct off the fan and remove it.
  13. Framework Desktop Antennas Replacement, Remove the fan: paso 13, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the fan: paso 13, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the fan: paso 13, imagen 3 de 3
    • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
  14. Framework Desktop Antennas Replacement, Disconnect the top Expansion Card cable: paso 14, imagen 1 de 2 Framework Desktop Antennas Replacement, Disconnect the top Expansion Card cable: paso 14, imagen 2 de 2
    • Pull the top Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  15. Framework Desktop Antennas Replacement, Disconnect the main power cable: paso 15, imagen 1 de 2 Framework Desktop Antennas Replacement, Disconnect the main power cable: paso 15, imagen 2 de 2
    • While squeezing the clip on the main power cable, pull it straight up and out of its socket to disconnect it.
  16. Framework Desktop Antennas Replacement, Disconnect the CPU power cable: paso 16, imagen 1 de 2 Framework Desktop Antennas Replacement, Disconnect the CPU power cable: paso 16, imagen 2 de 2
    • While squeezing the clip on the CPU power cable, pull it straight up and out of its socket to disconnect it.
  17. Framework Desktop Antennas Replacement, Disconnect the bottom Expansion Card cable: paso 17, imagen 1 de 2 Framework Desktop Antennas Replacement, Disconnect the bottom Expansion Card cable: paso 17, imagen 2 de 2
    • Pull the bottom Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  18. Framework Desktop Antennas Replacement, Reposition the Desktop: paso 18, imagen 1 de 2 Framework Desktop Antennas Replacement, Reposition the Desktop: paso 18, imagen 2 de 2
    • Lift the Desktop so it stands upright on your work surface.
  19. Framework Desktop Antennas Replacement, Remove the Right Panel: paso 19, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the Right Panel: paso 19, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the Right Panel: paso 19, imagen 3 de 3
    • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
    • Remove the Right Panel.
  20. Framework Desktop Antennas Replacement, Remove the top plate screws: paso 20, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the top plate screws: paso 20, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the top plate screws: paso 20, imagen 3 de 3
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
  21. Framework Desktop Antennas Replacement, Remove the top plate: paso 21, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the top plate: paso 21, imagen 2 de 2
    • Lift the top plate off the Desktop and remove it.
  22. Framework Desktop Antennas Replacement, Reposition the Desktop: paso 22, imagen 1 de 2 Framework Desktop Antennas Replacement, Reposition the Desktop: paso 22, imagen 2 de 2
    • Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
  23. Framework Desktop Antennas Replacement, Remove the Wi-Fi Module screw: paso 23, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the Wi-Fi Module screw: paso 23, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to remove the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  24. Framework Desktop Antennas Replacement, Remove the Wi-Fi module cover: paso 24, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the Wi-Fi module cover: paso 24, imagen 2 de 2
    • Use your fingers to slide the Wi-Fi module cover straight off the bottom of the module.
    • Remove the cover.
  25. Framework Desktop Antennas Replacement, Disconnect the Wi-Fi module: paso 25, imagen 1 de 3 Framework Desktop Antennas Replacement, Disconnect the Wi-Fi module: paso 25, imagen 2 de 3 Framework Desktop Antennas Replacement, Disconnect the Wi-Fi module: paso 25, imagen 3 de 3
    • The Wi-Fi module has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
    • Press and hold the Wi-Fi module down with your fingers.
    • Use your fingers to grip the white antenna cable, as close to the metal head as possible.
    • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
    • Gently lift the connector straight up to disconnect the white antenna cable.
    • Repeat the procedure with the black antenna cable.
  26. Framework Desktop Antennas Replacement, Remove the Wi-Fi module: paso 26, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the Wi-Fi module: paso 26, imagen 2 de 2
    • Grip the Wi-Fi module by its edges and pull it straight out of its socket.
    • Remove the Wi-Fi module.
  27. Framework Desktop Antennas Replacement, Reposition the Desktop: paso 27, imagen 1 de 2 Framework Desktop Antennas Replacement, Reposition the Desktop: paso 27, imagen 2 de 2
    • Rotate the Desktop onto its right side so the Mainboard is facing upward.
  28. Framework Desktop Antennas Replacement, Disconnect the power button: paso 28, imagen 1 de 2 Framework Desktop Antennas Replacement, Disconnect the power button: paso 28, imagen 2 de 2
    • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
  29. Framework Desktop Antennas Replacement, Remove the Mainboard screws: paso 29, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the Mainboard screws: paso 29, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to remove the four 8.2 mm‑long Phillips screws securing the Mainboard.
  30. Framework Desktop Antennas Replacement, Remove the Mainboard: paso 30, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the Mainboard: paso 30, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the Mainboard: paso 30, imagen 3 de 3
    • Grab the Mainboard by its heatsink and pull it towards the front of the Desktop to slide it out of the rear port cutout.
    • Slide the Mainboard towards the top of the Desktop to remove it from the chassis.
  31. Framework Desktop Antennas Replacement, Reroute the power button cable: paso 31, imagen 1 de 3 Framework Desktop Antennas Replacement, Reroute the power button cable: paso 31, imagen 2 de 3 Framework Desktop Antennas Replacement, Reroute the power button cable: paso 31, imagen 3 de 3
    • Pull the power button cable out of its rubber clips on the chassis.
  32. Framework Desktop Antennas Replacement, Reroute the antenna cables: paso 32, imagen 1 de 2 Framework Desktop Antennas Replacement, Reroute the antenna cables: paso 32, imagen 2 de 2
    • Push the antenna cables out of the metal hook in the chassis.
  33. Framework Desktop Antennas Replacement: paso 33, imagen 1 de 2 Framework Desktop Antennas Replacement: paso 33, imagen 2 de 2
    • Pull the black antenna cable out of the plastic clip in the chassis.
  34. Framework Desktop Antennas Replacement, Peel off the copper film: paso 34, imagen 1 de 2 Framework Desktop Antennas Replacement, Peel off the copper film: paso 34, imagen 2 de 2
    • Use your fingers to peel the left antenna's copper film off the chassis.
  35. Framework Desktop Antennas Replacement, Remove the left antenna screws: paso 35, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the left antenna screws: paso 35, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to remove the two 4.0 mm‑long Phillips screws securing the left antenna.
  36. Framework Desktop Antennas Replacement, Remove the left antenna: paso 36, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the left antenna: paso 36, imagen 2 de 2
    • Lift the left antenna out of the chassis and remove it.
  37. Framework Desktop Antennas Replacement, Peel off the copper film: paso 37, imagen 1 de 2 Framework Desktop Antennas Replacement, Peel off the copper film: paso 37, imagen 2 de 2
    • Use your fingers to peel the right antenna's copper film off the chassis.
  38. Framework Desktop Antennas Replacement, Remove the right antenna screws: paso 38, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the right antenna screws: paso 38, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to remove the two 4.0 mm‑long Phillips screws securing the right antenna.
  39. Framework Desktop Antennas Replacement, Remove the right antenna: paso 39, imagen 1 de 3 Framework Desktop Antennas Replacement, Remove the right antenna: paso 39, imagen 2 de 3 Framework Desktop Antennas Replacement, Remove the right antenna: paso 39, imagen 3 de 3
    • Lift the right antenna out of the chassis, making sure to thread the cable through the slot.
    • Remove the antenna.
  40. Framework Desktop Antennas Replacement, Disassembly complete: paso 40, imagen 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  41. Framework Desktop Antennas Replacement, Place the right antenna: paso 41, imagen 1 de 3 Framework Desktop Antennas Replacement, Place the right antenna: paso 41, imagen 2 de 3 Framework Desktop Antennas Replacement, Place the right antenna: paso 41, imagen 3 de 3
    • The replacement antennas look similar. The right antenna has a short, black antenna cable.
    • Place the replacement right antenna into its slot on the chassis, making sure to thread the cable through the slot.
  42. Framework Desktop Antennas Replacement, Install the right antenna screws: paso 42, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the right antenna screws: paso 42, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to install the two 4.0 mm‑long Phillips screws securing the right antenna.
  43. Framework Desktop Antennas Replacement, Remove the adhesive liner: paso 43, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the adhesive liner: paso 43, imagen 2 de 2
    • Remove the liner from the back of your replacement right antenna.
  44. Framework Desktop Antennas Replacement, Adhere the right antenna: paso 44, imagen 1 de 3 Framework Desktop Antennas Replacement, Adhere the right antenna: paso 44, imagen 2 de 3 Framework Desktop Antennas Replacement, Adhere the right antenna: paso 44, imagen 3 de 3
    • Press the right antenna's copper film onto the chassis and adhere it.
  45. Framework Desktop Antennas Replacement, Place the left antenna: paso 45, imagen 1 de 2 Framework Desktop Antennas Replacement, Place the left antenna: paso 45, imagen 2 de 2
    • The left antenna has a long, black antenna cable with a white tip.
    • Place the replacement left antenna into its slot on the chassis.
  46. Framework Desktop Antennas Replacement, Install the left antenna screws: paso 46, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the left antenna screws: paso 46, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to install the two 4.0 mm‑long Phillips screws securing the left antenna.
  47. Framework Desktop Antennas Replacement, Remove the adhesive liner: paso 47, imagen 1 de 2 Framework Desktop Antennas Replacement, Remove the adhesive liner: paso 47, imagen 2 de 2
    • Remove the liner from the back of your replacement left antenna.
  48. Framework Desktop Antennas Replacement, Adhere the left antenna: paso 48, imagen 1 de 3 Framework Desktop Antennas Replacement, Adhere the left antenna: paso 48, imagen 2 de 3 Framework Desktop Antennas Replacement, Adhere the left antenna: paso 48, imagen 3 de 3
    • Press the left antenna's copper film onto the chassis and adhere it.
  49. Framework Desktop Antennas Replacement, Reroute the antenna cables: paso 49, imagen 1 de 2 Framework Desktop Antennas Replacement, Reroute the antenna cables: paso 49, imagen 2 de 2
    • Press the black antenna cable into the plastic clip in the chassis.
  50. Framework Desktop Antennas Replacement: paso 50, imagen 1 de 2 Framework Desktop Antennas Replacement: paso 50, imagen 2 de 2
    • Pull the antenna cables into their metal hook in the chassis.
  51. Framework Desktop Antennas Replacement, Reroute the power button cable: paso 51, imagen 1 de 2 Framework Desktop Antennas Replacement, Reroute the power button cable: paso 51, imagen 2 de 2
    • Push the power button cable into its rubber clips on the chassis.
  52. Framework Desktop Antennas Replacement, Place the Mainboard: paso 52, imagen 1 de 3 Framework Desktop Antennas Replacement, Place the Mainboard: paso 52, imagen 2 de 3 Framework Desktop Antennas Replacement, Place the Mainboard: paso 52, imagen 3 de 3
    • Grab the Mainboard by its heatsink and slide it into the chassis.
    • Align the rear ports with its cutout and the screw posts with the screw holes on the Mainboard.
    • You'll feel the Mainboard rest onto the screw posts when it's aligned properly.
    • Make sure no cables are trapped underneath the Mainboard before continuing.
  53. Framework Desktop Antennas Replacement, Install the Mainboard screws: paso 53, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the Mainboard screws: paso 53, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to install the four 8.2 mm‑long Phillips screws securing the Mainboard.
  54. Framework Desktop Antennas Replacement, Connect the power button: paso 54, imagen 1 de 2 Framework Desktop Antennas Replacement, Connect the power button: paso 54, imagen 2 de 2
    • Slide the power button cable over the nine-pronged connector on the Mainboard.
  55. Framework Desktop Antennas Replacement, Reposition the Desktop: paso 55, imagen 1 de 2 Framework Desktop Antennas Replacement, Reposition the Desktop: paso 55, imagen 2 de 2
    • Rotate the Desktop onto its left side so the underside of the Mainboard is facing upward.
  56. Framework Desktop Antennas Replacement, Install the Wi-Fi module: paso 56, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the Wi-Fi module: paso 56, imagen 2 de 2
    • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
    • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
  57. Framework Desktop Antennas Replacement, Connect the Wi-Fi Module: paso 57, imagen 1 de 3 Framework Desktop Antennas Replacement, Connect the Wi-Fi Module: paso 57, imagen 2 de 3 Framework Desktop Antennas Replacement, Connect the Wi-Fi Module: paso 57, imagen 3 de 3
    • Hold the Wi-Fi module down with your fingers.
    • Position the black antenna cable connector over the left Wi-Fi module's coaxial socket.
    • Tweezers can help position the connector.
    • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
    • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
    • Repeat the procedure with the white antenna cable.
  58. Framework Desktop Antennas Replacement: paso 58, imagen 1 de 3 Framework Desktop Antennas Replacement: paso 58, imagen 2 de 3 Framework Desktop Antennas Replacement: paso 58, imagen 3 de 3
    • Hook the Wi-Fi bracket over the corner of the Wi-Fi module opposite the antenna cables.
    • Rotate the bracket over the Wi-Fi module, making sure the screw hole isn't being obstructed by the antenna cables.
  59. Framework Desktop Antennas Replacement, Install the Wi-Fi module screw: paso 59, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the Wi-Fi module screw: paso 59, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to install the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  60. Framework Desktop Antennas Replacement, Reposition the Desktop: paso 60, imagen 1 de 2 Framework Desktop Antennas Replacement, Reposition the Desktop: paso 60, imagen 2 de 2
    • Rotate the Desktop so it sits upright on your work surface.
  61. Framework Desktop Antennas Replacement, Place the top plate: paso 61, imagen 1 de 2 Framework Desktop Antennas Replacement, Place the top plate: paso 61, imagen 2 de 2
    • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
  62. Framework Desktop Antennas Replacement: paso 62, imagen 1 de 2 Framework Desktop Antennas Replacement: paso 62, imagen 2 de 2
    • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
  63. Framework Desktop Antennas Replacement, Install the top plate screws: paso 63, imagen 1 de 3 Framework Desktop Antennas Replacement, Install the top plate screws: paso 63, imagen 2 de 3 Framework Desktop Antennas Replacement, Install the top plate screws: paso 63, imagen 3 de 3
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
  64. Framework Desktop Antennas Replacement, Install the Right Panel: paso 64, imagen 1 de 3 Framework Desktop Antennas Replacement, Install the Right Panel: paso 64, imagen 2 de 3 Framework Desktop Antennas Replacement, Install the Right Panel: paso 64, imagen 3 de 3
    • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Right Panel and the silver base.
    • Push the Right Panel towards the base of the computer to engage the clips.
  65. Framework Desktop Antennas Replacement, Reposition the Mainboard: paso 65, imagen 1 de 2 Framework Desktop Antennas Replacement, Reposition the Mainboard: paso 65, imagen 2 de 2
    • Lay the right side of the Desktop on your work surface so the Mainboard is facing upward.
  66. Framework Desktop Antennas Replacement, Connect the bottom Expansion Card cable: paso 66, imagen 1 de 2 Framework Desktop Antennas Replacement, Connect the bottom Expansion Card cable: paso 66, imagen 2 de 2
    • Slide the bottom Expansion Card cable into its socket on the Mainboard.
  67. Framework Desktop Antennas Replacement, Connect the CPU power cable: paso 67, imagen 1 de 2 Framework Desktop Antennas Replacement, Connect the CPU power cable: paso 67, imagen 2 de 2
    • Orient the CPU power supply cable so its clip is facing the heatsink.
    • Slide the cable into its socket on the Mainboard until you feel it click into place.
  68. Framework Desktop Antennas Replacement, Connect the main power cable: paso 68, imagen 1 de 2 Framework Desktop Antennas Replacement, Connect the main power cable: paso 68, imagen 2 de 2
    • Orient the main power supply cable so its clip is facing away from the heatsink.
  69. Framework Desktop Antennas Replacement, Connect the top Expansion Card cable: paso 69, imagen 1 de 2 Framework Desktop Antennas Replacement, Connect the top Expansion Card cable: paso 69, imagen 2 de 2
    • Slide the top Expansion Card cable into its socket on the Mainboard.
  70. Framework Desktop Antennas Replacement, Insert the fan: paso 70, imagen 1 de 3 Framework Desktop Antennas Replacement, Insert the fan: paso 70, imagen 2 de 3 Framework Desktop Antennas Replacement, Insert the fan: paso 70, imagen 3 de 3
    • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
    • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
    • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
    • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
  71. Framework Desktop Antennas Replacement: paso 71, imagen 1 de 3 Framework Desktop Antennas Replacement: paso 71, imagen 2 de 3 Framework Desktop Antennas Replacement: paso 71, imagen 3 de 3
    • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
    • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
  72. Framework Desktop Antennas Replacement, Insert the fan duct: paso 72, imagen 1 de 2 Framework Desktop Antennas Replacement, Insert the fan duct: paso 72, imagen 2 de 2
    • Lay the fan duct on top of the fan with the lip facing upward.
    • Align the screw holes on the fan duct with the ones on the fan.
  73. Framework Desktop Antennas Replacement, Install the fan screws: paso 73, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the fan screws: paso 73, imagen 2 de 2
    • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long screws securing the fan and fan duct.
  74. Framework Desktop Antennas Replacement, Connect the fan: paso 74, imagen 1 de 2 Framework Desktop Antennas Replacement, Connect the fan: paso 74, imagen 2 de 2
    • Orient the main fan cable so its two vertical lines are facing you.
    • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
  75. Framework Desktop Antennas Replacement, Connect the RGB cable: paso 75, imagen 1 de 3 Framework Desktop Antennas Replacement, Connect the RGB cable: paso 75, imagen 2 de 3 Framework Desktop Antennas Replacement, Connect the RGB cable: paso 75, imagen 3 de 3
    • Orient the RGB cable so the arrow is on the right side of the connector.
    • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
  76. Framework Desktop Antennas Replacement, Loosen the heat spreader screw: paso 76, imagen 1 de 1
    • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
  77. Framework Desktop Antennas Replacement, Install the SSD: paso 77, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the SSD: paso 77, imagen 2 de 2
    • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • While holding the heat spreader upright, align the SSD's gold contacts with its socket.
    • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
  78. Framework Desktop Antennas Replacement, Install the SSD screw: paso 78, imagen 1 de 3 Framework Desktop Antennas Replacement, Install the SSD screw: paso 78, imagen 2 de 3 Framework Desktop Antennas Replacement, Install the SSD screw: paso 78, imagen 3 de 3
    • Insert your Framework Desktop Screwdriver into the captive screw on the primary storage heat spreader and press it flat to the Mainboard.
    • Tighten the screw securing the SSD.
  79. Framework Desktop Antennas Replacement, Install the Left Panel: paso 79, imagen 1 de 3 Framework Desktop Antennas Replacement, Install the Left Panel: paso 79, imagen 2 de 3 Framework Desktop Antennas Replacement, Install the Left Panel: paso 79, imagen 3 de 3
    • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Left Panel and the silver base.
    • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
  80. Framework Desktop Antennas Replacement, Install the Top Panel: paso 80, imagen 1 de 3 Framework Desktop Antennas Replacement, Install the Top Panel: paso 80, imagen 2 de 3 Framework Desktop Antennas Replacement, Install the Top Panel: paso 80, imagen 3 de 3
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
  81. Framework Desktop Antennas Replacement: paso 81, imagen 1 de 2 Framework Desktop Antennas Replacement: paso 81, imagen 2 de 2
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  82. Framework Desktop Antennas Replacement, Install the Handle: paso 82, imagen 1 de 2 Framework Desktop Antennas Replacement, Install the Handle: paso 82, imagen 2 de 2
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
  83. Framework Desktop Antennas Replacement, Install the top panel screws: paso 83, imagen 1 de 3 Framework Desktop Antennas Replacement, Install the top panel screws: paso 83, imagen 2 de 3 Framework Desktop Antennas Replacement, Install the top panel screws: paso 83, imagen 3 de 3
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
  84. Framework Desktop Antennas Replacement: paso 84, imagen 1 de 3 Framework Desktop Antennas Replacement: paso 84, imagen 2 de 3 Framework Desktop Antennas Replacement: paso 84, imagen 3 de 3
    • Repeat the same procedure for the other top panel screw.
  85. Framework Desktop Antennas Replacement: paso 85, imagen 1 de 3 Framework Desktop Antennas Replacement: paso 85, imagen 2 de 3 Framework Desktop Antennas Replacement: paso 85, imagen 3 de 3
    • Use your finger to close the two D-rings on the top panel screws.
Conclusión
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
212,629 Reputación
1,039 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 53
Todo El Tiempo: 53
