Saltar al contenido principal
Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement
  1. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 1 de 1
    • Pull out the hood release in the driver's footwell to pop open the hood.
  2. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: paso 2, imagen 1 de 2 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: paso 2, imagen 2 de 2
    • Release the hood latch to lift the hood.
    • To avoid difficulty finding the latch, search near the center of the hood.
  3. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: paso 3, imagen 1 de 2 Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: paso 3, imagen 2 de 2
    • Position hood prop rod into the support hole.
    • Hoods are heavy and the securement of the prop rod is necessary to prevent injury.
  4. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: paso 4, imagen 1 de 1
    • Unlatch the three clips securing the engine air filter cover. (The third clip can't be seen in the photo but is on the other side of the cover.)
    • Be sure to allow the vehicle to cool down before working in the engine bay.
  5. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: paso 5, imagen 1 de 1
    • Gently remove the air filter cover.
  6. Fourth Generation (2011 - 2017) Honda Odyssey Engine Air Filter Replacement: paso 6, imagen 1 de 1
    • Remove the filter by simply pulling it out of the filter compartment.
Conclusión
Ahmad Elahi
Miembro Desde 01/21/21
169 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 40
Todo El Tiempo: 762
