Saltar al contenido principal
Fossil Q Marshal Gen 2 Screen Replacement
Qué necesitas
  1. Fossil Q Marshal Gen 2 Screen Replacement, Back Cover: paso 1, imagen 1 de 1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Screen Replacement: paso 2, imagen 1 de 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Screen Replacement: paso 3, imagen 1 de 2 Fossil Q Marshal Gen 2 Screen Replacement: paso 3, imagen 2 de 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Screen Replacement: paso 4, imagen 1 de 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Screen Replacement: paso 5, imagen 1 de 3 Fossil Q Marshal Gen 2 Screen Replacement: paso 5, imagen 2 de 3 Fossil Q Marshal Gen 2 Screen Replacement: paso 5, imagen 3 de 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Screen Replacement, Screen: paso 6, imagen 1 de 2 Fossil Q Marshal Gen 2 Screen Replacement, Screen: paso 6, imagen 2 de 2
    • The screen can now be removed out of the front-side of the watch.
Conclusión
12 personas más completaron esta guía.
Matthew Tucker
Miembro Desde 11/07/17
580 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G5, Harley Fall 2017 Miembro de IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Miembros
6 Guías creadas
17 comentarios
Where can i find a replacement screen for the founder q 2.0 version?
Jack Seitz - Contestar
Where can I buy replacement screen for gen 1
David Aslamazashvili -
Is the screen glued to the bezel of the watch?
Jose - Contestar
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Alexis Stellato - Contestar
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
evans.nathan6 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 12
Ultimos 30 días: 61
Todo El Tiempo: 18,933
